Not able to connect to Milestone Mobile Server over https.
I am not able to connect to Milestone Mobile server over https. The problem started after we tried to configure the Mobile server’s https port to a new port(the default https port is 8082). We tried changing the https port and generate a new self signed certificate. It gave “Cannot edit certificate error” and since then https connection is failing.The error in Milestone Mobile server log is -
2019-06-11;2:08:09 PM;Error;ProcessData;Object reference not set to an instance of an object.
2019-06-11;2:08:13 PM;Error;DeviceScanner.RequestCallback;Cannot access a disposed object.
Object name: ‘System.Net.Sockets.Socket’.
2019-06-11;2:09:29 PM;Error;ProcessData;Object reference not set to an instance of an object.
We are using Milestone 2018 R3.
