Not able to see the bounding boxes consistently.
Hi Team
There is a problem I am having while showing the bounding boxes. Sometimes it appears for some period of time (2-3sec). But if I post the same message again then, there is no bounding box visible on the Screen.
For reference, I am adding the XML message which I am posting.
00000000-0000-0000-0000-000000000000
$timestamp$
MyType
MyAnalyticsEvent01
TagFromXML
0.0.0.1,3
Rectangle
A suspect item
true
0.42
0.23
0.54
0.55
Can you please see this sample and test if it works for you?
https://doc.developer.milestonesys.com/html/index.html?base=samples/pluginsamples/scoverlaygraphonevent/readme.html&tree=tree_1.html
NOTE – This link is Events and Analytics integration documentation. It might be helpful to understand them.
https://content.milestonesys.com/media/?mediaId=39A14041-0077-437C-B4EEB8E6507CFFB6
https://github.com/milestonesys/mipsdk-samples-protocol/tree/main/TriggerAnalyticsEventXML
I have used this sample application to publish the event.
This plugin sample can display overlay in Live and Playback on SC when analytics events trigger. So please test the plugin sample and check if you can see it.
If there is no plugin sample then you cannot see overlay because Smart Client does not have functionality to see overlay.
