NotAuthorizedMIPException: VMO61008: You do not have sufficient permissions to complete the operation.
Hi~,
I have a question. I get an exception to login using interface “VideoOS.Platform.SDK.Environment.Login”. The exception log is shown in the figure.
he user information used here can log in to ManagementClient normally, but cannot log in in my service process.
The MIPSDK version is 2021R2.
Best Regard!​​
If you try the CameraStreamResolution sample unmodified, do you see the same error?
If the sample works, try to compare your code to that of the sample.
https://doc.developer.milestonesys.com/html/index.html?base=samples/componentsamples/camerastreamresolution/readme.html&tree=tree_2.html
Note. It is recommended to always use the newest MIP SDK while developing, please use the newest.
