NotImplementedException on Configuration.Instance.DeleteItemConfiguration
Any ideas on why this is happening?
System.NotImplementedException
HResult=0x80004001
Message=Metoden eller åtgärden har inte implementerats.
Source=VideoOS.Platform.SDK
StackTrace:
at VideoOS.Platform.SDK.Platform.SDKConfiguration.DeleteItemConfiguration(Guid platformDefinitionId, Item item)
at TryggRetail_Configurator.ConfigForm.deleteItemBtn_Click(Object sender, EventArgs e) in [E:\Dev\GitHub\TryggRetail\TryggRetail\TryggRetail](file:E:/Dev/GitHub/TryggRetail/TryggRetail/TryggRetail) Configurator\ConfigForm.cs:line 110
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at TryggRetail_Configurator.Program.Main() in [E:\Dev\GitHub\TryggRetail\TryggRetail\TryggRetail](file:E:/Dev/GitHub/TryggRetail/TryggRetail/TryggRetail) Configurator\Program.cs:line 33
Unfortunately the reason is that the DeleteItemConfiguration method has not been implemented for the standalone environment. So far it has only been implemented for Management Client and Event Server environments.
Sorry that the documentation does not reflect this.
We will investigate whether the functionality can be implemented for the 2018 R2 release.
