Hi
We just recently started to get an exception within the WPF player without any major changes in code. One customer had 5 such incidents during the weekend. We are using MIPSDK 23.2.1 in a standalone component integration. The exception is thrown when “maximizing” a player, i.e. taking a smaller player and replacing it with a new larger player with the same setup. I think the exception is thrown when the new player that is being constructed.
Attaching callstack from one such incident. The camera in this case is a Bosch FLEXIDOME IP starlight 6000 VR (CPP7).
The player is created something like this:
var imageViewerControl = new ImageViewerWpfControl
EnableVisibleHeader = false,
EnableMouseControlledPtz = true,
EnableMousePtzEmbeddedHandler = false,
EnableDigitalZoom = true,
MaintainImageAspectRatio = true,
Selected = IsSelected
imageViewerControl.CameraFQID = item.FQID;
imageViewerControl.Initialize();
imageViewerControl.Connect();
The callstack:
2024-10-26 15:05:45,881 [134:1] DEBUG Tennotech.Hilding.Watchman.App - Stacktrace:
vid VideoOS.Platform.SDK.UI.PlatformImageViewerWpfControl.get_DoMouseControlledPTZ()
vid VideoOS.Platform.SDK.UI.PlatformImageViewerWpfControl._smartClientVideoPlayer_PtzCenterPerformed(Object sender, PtzCenterEventArgs e)
vid System.EventHandler`1.Invoke(Object sender, TEventArgs e)
vid VideoOS.UI.Common.WPF.VideoPlayer.Model.PtzModel.HandleCenterOperation(Point relativePoint)
vid VideoOS.UI.Common.WPF.VideoPlayer.Control.UI.PTZOverlay.Handlers.RectanglePtzModeHandler.RectangleHandler_OnMouseLeftButtonUp(Object sender, MouseButtonEventArgs e)
vid System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
vid System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
vid System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
vid System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
vid System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
vid System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
vid System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
vid System.Windows.Input.InputManager.ProcessStagingArea()
vid System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
vid System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
vid System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
vid System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
vid System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
vid MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
vid MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
vid System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
vid System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
The NullReferenceException is thrown from PlatformImageViewerWpfControl.DoMouseControlledPTZ. Any ideas?
Best regards,
Ola Nygren, Tennotech
