I am working with the version XProtect 2023 R1 and calling the ONVIF methods to retrieve recordings using the following code.
foreach (var profile in profiles)
Console.WriteLine($“Profile Name: {profile.Profile.Name}”);
Console.WriteLine($“Profile CameName: {profile.Profile.VideoSourceConfiguration.Name}”);
Console.WriteLine($“Profile Uri: {profile.UriStreaming}”);
DateTime targetDate = new DateTime(2024, 12, 11, 0, 0, 0, DateTimeKind.Utc); // Medianoche del día deseado
DateTime endDate = new DateTime(2024, 12, 11, 23, 59, 59, DateTimeKind.Utc); // Fin del día deseado
// Calcular tiempo en milisegundos desde el timestamp
double millisecondsBefore = (targetDate - targetDate.AddDays(-1)).TotalMilliseconds;
double millisecondsAfter = (endDate - targetDate).TotalMilliseconds;
SourceReference sourceReference = new SourceReference()
Token = profile.Profile.VideoSourceConfiguration.SourceToken
// Configurar el filtro
SearchScope scope = new SearchScope()
IncludedSources = new SourceReference\[\] { sourceReference },
RecordingInformationFilter = $"boolean(//Track\[TrackType = 'Video'\]),{targetDate:yyyy-MM-ddTHH:mm:ssZ},1,1000,{millisecondsAfter},1000"
EventFilter eventFilter = new EventFilter()
var summary = await camera.Search.GetRecordingSummaryAsync();
Onvif.Search.GetRecordingSearchResultsResponse searchRecordings = new GetRecordingSearchResultsResponse();
try
var recordings = await camera.Search.FindRecordingsAsync(scope, 100, "PT30S");
searchRecordings = await camera.Search.GetRecordingSearchResultsAsync(recordings.SearchToken, 100, 100, "PT30S");
catch (Exception ex)
Console.WriteLine($"Se ha producido un errror al buscar grbaciones {ex.Message}");
GetEventSearchResultsResponse searchEvents = new GetEventSearchResultsResponse();
try
var events = await camera.Search.FindEventsAsync(targetDate, endDate, scope, eventFilter, true, 100, "PT30S");
searchEvents = await camera.Search.GetEventSearchResultsAsync(events.SearchToken, 100, 100, "PT30S");
Console.WriteLine($"Se ha producido un errror al buscar eventos {ex.Message}");
var recordingInfoList = new List();
if (searchRecordings.ResultList != null && searchRecordings.ResultList.RecordingInformation != null)
foreach (var recording in searchRecordings.ResultList.RecordingInformation)
var mediaatributtes = await camera.Search.GetMediaAttributesAsync(new string\[\] { recording.RecordingToken }, targetDate);
var streamUri = await camera.Replay.GetReplayUriAsync(
new Onvif.Replay.StreamSetup
Stream = Onvif.Replay.StreamType.RTPUnicast,
Transport = new Onvif.Replay.Transport { Protocol = Onvif.Replay.TransportProtocol.RTSP }
}, recording.RecordingToken
Console.WriteLine($"Fechas Grabación {recording.EarliestRecording},{recording.LatestRecording}");
Console.WriteLine($"Uri Replay:{streamUri.Uri}");
//var recordingJobs = await camera.Recording.GetRecordingJobsAsync();
else
Console.WriteLine("No se han encontrado grabaciones");
//foreach (var events in searchEvents.ResultList.Result.ToList())
// Console.WriteLine($“Eventos {events.Event.Message.InnerXml},{events.Time}”);
When the GetMediaAttributesmethod is executed, the ONVIF server crashes. The same issue occurs with the GetRecordingJobs and FindEvents methods, which also return errors.
The error visible in the Event Viewer on the Milestone server is as follows:
