We are using Milestone ONVIF Bridge For Xprotect 2018 R3.
The problem is that we are having some RTSP video flows with different image resolution than the original camera despite the fact that we made sure that the ONVIF bridge setting is set to “Use the configurations from the cameras”
The camera resolution is 3584 X 2688 but when getting the video stream we ends up getting this resolution 1792X1344
Thank you in advance.
