ONVIF Bridge Service Stops with Errors and never restarts
We are testing our application against the latest ONVIF Brdige, 2017 R1.
When using our test license and computer the server starts both the ONVIF service and RTSP service fine. It runs and streams video for a while and then will stop itself gracefully and NOT restart.
Manually restarting seems to work.
The logs and configurations are attached. This is causing us major issues and to seriously reconsider if we wan to develop around the ONVIF bridge.
we see these types of errors:
24-03-2017 09-27-00.415: Error - LiveImplementer::InternalGetNextFrames: ImMediaData is NULL
24-03-2017 09-27-04.415: Error - LiveImplementer::InternalGetNextFrames: ImMediaData is NULL
24-03-2017 09-27-07.759: Warning - RtspConnection::Client_proccess, bytes length provided by recv() is 0
24-03-2017 09-27-11.306: Info - Recorder URL: http://testonviflaptop:7563/
24-03-2017 09-27-11.493: Error - LiveImplementer::InternalGetNextFrames: ImMediaData is NULL
Fuul Logs for ONVIF and RTSP attached.
That the Onvif Bridge does not work is as expected will have to be dealt with in Milestone Support. Please open a support case or seek advise in the Support Community. https://force.milestonesys.com/support/MccSupportCommunity
When you open a support case my advise is to include details that Milestone can attempt to reproduce the issue and include some network communication trace to show the communication with the ONVIF Bridge.
Did this issue is solved or not? I have same issue like this.
Support Community is at https://force.milestonesys.com/support/MccSupportCommunity
