We have implemented the ONVIF Profile G, Search and Reply API in our device. As our device has two cameras. We want to see an individual timeframe for two cameras for edge recording in Single IP-based device. how we can do it. ?
If your device reports the two cameras as two Video Sources, then just add the device in XProtect using the ONVIF driver (or ONVIF16 if using older version of XProtect). You device will appear with 2 video channels.
In Smart Client in the Playback tab you can add the 2 video channels to the view, from which you can see and retrieve Edge recordings.
See Retrieval of Remote Recordings from the ONVIF Driver Overview document.
Also make sure that your device conforms to our ONVIF Profile G recording retrieval process for Multichannel devices as specified in:
