ONVIF edge storage on NVR
We are testing NVR on Milestone.Milestone can get video back from local storage of NVR after network between Milestone and NVR recoverd.But just with one channel(camera).
If we pluged several camera into NVR,then connect into Milestone.We can’t retrieve video back after network recover again.(We found the video NVR send to Milestone is refused.)
You have a NVR added to XProtect using the ONVIF driver and see some issues with it?
If I understand the situation correctly you are experiencing errors and you have not developed an integration using the MIP SDK that cause this error.
If my understanding is correct this is a question suited for the Milestone Support Community.
Submitted just now.Thank you for your kind reminder.
