Hello everyone,
I’m here to report an issue found during ONVIF Profile G edge recording recovery (Netbreak) in Milestone XProtect 2025 R1, using a multisensor camera that correctly exposes recording data and RTSP SDP (audio + video), but Milestone requests SETUP only for the audio track. The video track is never requested.
The behavior is reproducible and specific to the multisensor Profile G device.
Environment
VMS: Milestone XProtect 2025 R1 (25.1b)
Device Pack: 13.6.1740.1
Authentication: HTTP Digest
Recording Mode: Edge recording with automatic recovery
Protocol: ONVIF Profile G (Recording / Search / Replay) + RTSP
Device Under Test
Brand: BOS**
Model:** BS-IPPAN3432FCMZD+
Firmware: VC44.45.1.3.0-251212
Type: Multisensor IPC (4 channels)
Device characteristics:
ONVIF Profile S, G, T certified
Listed on ONVIF official website
Passes ONVIF Device Test Tool (Profile G preliminary checks)
Implements Recording, Search, Replay services
Returns multiple RecordingTokens and VideoTrackTokens
The device is formally Profile G compliant.
ONVIF Flow
During edge recovery, Milestone correctly performs:
Device discovery
Recording search
GetMediaAttributes
Retrieval of multiple RecordingTokens and associated TrackTokens
No anomalies observed at SOAP level.
RTSP Session (Wireshark Analysis)
Sequence:
Milestone sends
DESCRIBE -
Camera replies with SDP including:
m=video(trackID=1) -
m=audio(trackID=2)
Milestone sends:
SETUP→ audio track only (trackID=2)
No
SETUPis sent for video (trackID=1) -
PLAY→ 200 OK -
RTP session established → audio only
No video RTP packets received (as expected, since no SETUP)
Replay session is technically established but contains no video.
The decision not to request video appears to occur before RTSP negotiation.
The behavior may be related to how Milestone handles:
Multiple RecordingTokens
Multiple VideoTrackTokens
Multisensor logical channel mapping
RecordingTrack / SourceToken associations
Metadata interpretation in GetMediaAttributes or Search results
The camera:
Properly returns SDP with valid video media section
Is capable of streaming video normally outside Profile G recovery
Responds correctly to RTSP when video SETUP is explicitly requested
There is no RTSP-level rejection or transport error.
For context, we have already been in direct contact with Milestone Technical Support regarding this issue.
Over the course of several months, multiple remote sessions were conducted, including extensive testing and detailed log analysis performed together with the assigned support engineer. After thorough investigation and review of the collected logs, it was concluded that the abnormal behavior does not appear to originate from the camera side.
Based on the analysis, we were informed that the issue seems to be related to how Milestone handles multi-channel / multisensor events and track management during the Profile G edge recovery process.
For this reason, we were advised to escalate the matter to the Driver Team, as the root cause appears to be linked to Milestone’s internal handling of multi-channel devices rather than to ONVIF compliance or RTSP behavior on the device side.
