I attempted the reverse playback on ONB via VLC, at -1 setting, it did not play in reverse and only displayed a static image from the camera. Using 3rd party clients also shows similar results (at -5 playback, it becomes a slide show). Is this the typical experience for the reverse playback function? is there an alternative to achieve reverse playback ?
