Opening the menu Tools > Options in Milestone Management Server crashes
After opening the application Management Server, I go to the Menu Tools, I select the entry Options, but the Options does not load.
Instead, a window opens and I can only click on the button to close it; but no options window pops up.
When I close that window, another one pops up:
Then, the application is frozen and a new pop up shows, describing an exception error:
Do you have any idea about what can be happening, plesae?
Thank you very much and have a nice day.
OK…
Solved it…
I found this information in this link:
https://developer.milestonesys.com/s/question/0D50O000054fdc6SAA/client-error-from-my-first-dll-default-guid-has-not-been-replaced
I overwrote the IDs of the interfaces as it is explained there:
I sought with CTRL + SHIFT + F in Visual Studio for the string “internal static Guid”
and I changed the numbers so they would be different
(For one of the test PlugIns I am using, I added 1 to each value; and for the other I added 2 to each value)
I compiled the PlugIns, copied the *.DLL files in their respective folders of the PlugIns
Then I was able to open the Menu “Tools > Options”
