Overlay polygon or bounding box line thickness setting?
Is there a way to set the overlay polygon or bounding box line thickness?
If you are submitting metadata the BoundingBoxMetadataProvider sample uses a varying line thickness.
If you are submitting analytics events there is no way to specify line thickness.
