Overlay text ontop over Axis dewarper plugin
I have created an overlay to shop certain data as per company requirements using hte overlay example as a basis for this, however this does not overlay ontop of Axis dewarper plugin views. does anyone know how to achieve this?
I assume, you referred Active Elements Overlay sample as base of your plugin, please correct me if I am wrong, but did unmodified sample work for you?
Hi, no it did not. It only overlaid on native milestone views, when we use the dewarping plugin we drag a dewarping view onto the page (see below) I assume I need to tell milestone to display over this view but currently I am only displaying over native elements.
The overlays (ShapesOveralyAdd - ActiveElementsOverlayAdd) works not only on native camera views but also on integrations that rely on the Image Viewer like the Video Preview plugin sample. However if the plugin does not use the Image Viewer component but replaces it with something else then we miss the thing that does the overlay. This is the case here with the Axis Dewarp.
Please note: I do not know exactly how Axis have developed the plugin, but I must assume that this principle has been used - https://download.milestonesys.com/MIPSDK/Samples/MilestoneConceptDewarp.pdf).
Some samples that use overlay and the mentioned Video Preview..
https://doc.developer.milestonesys.com/html/index.html?base=samples/pluginsamples/analyticsoverlay/readme.html&tree=tree_1.html
https://doc.developer.milestonesys.com/html/index.html?base=samples/pluginsamples/scoverlaygraphonevent/readme.html&tree=tree_1.html
https://doc.developer.milestonesys.com/html/index.html?base=samples/pluginsamples/activeelementsoverlay/readme.html&tree=tree_1.html
https://doc.developer.milestonesys.com/html/index.html?base=samples/pluginsamples/videopreview/readme.html&tree=tree_1.html
