We are going to develop milestone playback functionality using Protocol Integration (because we use Linux OS). I saw in MIP code example, for SDK integration, there are ‘PlayForward’ and ‘PlayReverse’. For protocol integration, how can we achieve similar ‘PlayForward’ and ‘PlayReverse’ functionality? I saw in protocol integration, it has only ‘goto’, 'next, and ‘previous’ requests (https://doc.developer.milestonesys.com/html/reference/protocols/imageserver_request_response.html#a5) but I can not find PlayForward or PlayReverse.
- Could you please give recommendation how should we develop PlayForward and PlayReverse capabilities? Is there any documentation we should start with? With the only ‘next’ request available in protocol integration, does it mean we must send ‘next’ again and again repetitively to achieve PlayForward?
- With protocol integration, is there a way to retrieve playback between two timestamps and play the video between these specified timestamps and automatically stop the playback once it reaches timestamp end?
Thank you for your help
