We have a plugin which works fine in Professional+ and are now trying to load it into Professional. We added to the [C:\Program](file:C:/Program) Files (x86)\Milestone\Milestone Surveillance\MIPPlugins\ folder
However our plugin does not get loaded.
2019-04-26 4:20:58 PM Error: MIPPluginLoad (RookArchive.dll):Exception source: mscorlib
Exception type: System.BadImageFormatException
Exception message: Could not load file or assembly ‘file:///[C:\Program](file:C:/Program) Files (x86)\Milestone\Milestone Surveillance\MIPPlugins\StorageQuest RookArchive\RookArchive.dll’ or one of its dependencies. An attempt was made to load a program with an incorrect format.
Exception target site: _nLoad
at System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
at System.Reflection.RuntimeAssembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
at System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, RuntimeAssembly reqAssembly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
at System.Reflection.RuntimeAssembly.InternalLoadFrom(String assemblyFile, Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm hashAlgorithm, Boolean forIntrospection, Boolean suppressSecurityChecks, StackCrawlMark& stackMark)
at System.Reflection.Assembly.LoadFrom(String assemblyFile)
at VideoOS.Platform.Util.PluginManager.FindPlugins(String fileName, Type typeToLoad)
at VideoOS.Administrator.Platform.XPEEnvironmentManager.Log(String name, Boolean error, String where, String text, Object[] args)
at VideoOS.Administrator.Platform.XPEEnvironmentManager.ExceptionHandler(String name, String where, Exception exception)
at VideoOS.Platform.Util.PluginManager.LoadFromFolder(String folderPath, Type pluginInterfaceType, String pluginDefName)
at VideoOS.Platform.Util.PluginManager.Initialize()
at VideoOS.Administrator.Platform.PlatformPlugin.InitializePlugin(IPluginServer server)
at VideoOS.Administrator.PluginUtilities10.BasePlugin.VideoOS.Administrator.PluginInterfaces.IPlugin.InitializePlugin(IPluginServer server)
at VideoOS.Administrator.Framework.Plugins.PluginManager.InitializePlugins()
at VideoOS.Administrator.Framework.Plugins.PluginManager.LoadPlugins()
at VideoOS.Administrator.Application.Program.Main(String[] Args)
