Problem:
After a fresh installation of xprotect essential+ on a windows 2016
server with
All working fine except the mobile service. first I notice crashing
images in the mobile client app. as well on the web client. this started when I
try to zoom in on a camera image in live view. the image was flashing grey
every second. I was also connected with the windows client at the same moment.
this image kept clear with good quality. All was looking normal on the server.
only 10% cpu en mem was under 50%. No errors in the log. after switching from
cameras in the mobile client app I notice the mobile service was crashing and
was restarted automatically.
windows log:
Application: VideoOS.MobileServer.Service.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: exception code c0000005, exception address
00007FFDCD984E0D
Solution:
after spending days on this server I found the solution.
I notice the % maximum cpu frequency was running on ± 60% in the
resource manager. when i did a stress test on the server to trigger the need
for cpu it goes up to 100% automatic. after this I tried to trigger the need
for cpu on the xprotect services. when I changed the motion detect to 100%
detection resolution and process every 100msec the cpu went up as expected.
after another day I tried to change the default windows power settings
in control panel, power options. this was default on “Balanced”. when
I changed this option to High performance the issue with the mobile service was
solved directly!!
I’m not sure if this is some bug but normally when a system is in
balance mode it should increase the cpu clock frequency when there’s a need for
more cpu. with all other processes this is happening but not for the mobile
service.
My hardware:
Mainboard, Intel server board S5520HC dual cpu, E5605@2.13Ghz, 8GB RAM
Storage, dual 500GB SSD running raid 1, 4 x 1TB SATA running raid 5, all
on hardware raid controller.
