Prevent big packets transmission and controlling MTU sent from the server.
We are encountering an issue, we have cellular system with milestone server
and when we’re using the milestone application on the android the video quality gets very low and the connection to the server gets lost.
so after some research we’ve found that the milestone server send very big packets, around 5000 MBytes, we’re guessing that these big packets takes to long and takes lots of resources to cut and reassemble and that cousin the problem.
is there a way to limit the size of the packet, change the MTU on the server?
(we tried to limit it in the OS but it didn’t helped)
also we’ll be happy to hear other suggestions to solve our issue.
this is an urgent matter!
thank you.
anyone? please…
https://force.milestonesys.com/support/MccSupportCommunity
