Programmatically change workspace in SmartClient
I would like to change the displayed workspace in the SmartClient based on received messages on a background plugin within the SmartClient. I have tried both the messages below but may not have set the parameters correctly and could not find an applicable example.
message = new VideoOS.Platform.Messaging.Message(VideoOS.Platform.Messaging.MessageId.SmartClient.ShowWorkSpaceCommand, null);
message.RelatedFQID = new FQID(EnvironmentManager.Instance.MasterSite.ServerId, FolderType.No,ClientControl.LiveBuildInWorkSpaceId);
EnvironmentManager.Instance.SendMessage(message, null, null);
and
messageData = Mode.ClientLive;
message= new VideoOS.Platform.Messaging.Message(VideoOS.Platform.Messaging.MessageId.SmartClient.ChangeModeCommand, messageData);
EnvironmentManager.Instance.SendMessage(message,null, null);
Please let me know the proper approach to programmatically change the displayed workspace in the SmartClient.
After some more experimentation, I have found the below code switches the displayed workspace:
List wsps = ClientControl.Instance.GetWorkSpaceItems();
foreach (Item itm in wsps)
if (itm.Name.Contains(“Live”))
 message.RelatedFQID = itm.FQID;
 ClientControl.Instance.CallOnUiThread(() => EnvironmentManager.Instance.SendMessage(message, null, null));
 break;
Hi @John Moody​ ,
May I know if this is only available for plugin but not EnviromentType.Standalone?
I wanted to do the same thing:
Switching WorkSpace tabs on the Smart Client.
But my program failed to run the following statement:
I tried to try-and-catch the statement but no error was found and
the program terminate itself.
Or do I need to do some initialization things before I can call the
GetWorkSpaceItems() function?
Hope to hear from you, thanks.
