Property EnableMouseControlledPtz does not work
I’m writing the following code:
_imageViewer.EnableMouseControlledPtz = false;
But mouse control is still there.
Can you please tell me what to do. Thank you.
I experimented with the PTZandPresets sample, I modified these two lines:
        \_imageViewerControl.EnableMouseControlledPtz = false;
        \_imageViewerControl.EnableMousePtzEmbeddedHandler = false;
(was originally both true)
then mouse controlled PTZ was disabled.
I cannot really see or explain why there are two properties and what the difference is. I hope you are satisfied it works if using both.
