ХProtect mobile client does not work when switching from internal mobile server to external
XProtect mobile client does not work when switching from an internal mobile server to an external one. There is an internal server with the name srv-int and an external server with the name srv-ext, a single DNS entry for access has been created for the servers xprotect.company.com.
The problem is that in the latest version of the mobile application, automatic address switching does not work, in previous versions everything worked.
How to fix this problem ?
