We are trying to integrate with the Access Control Module (ACM) using the SOAP API Protocol Integration. Is this possible?
How can we accomplish this?
Thank you
Thank you
Access Control Module (ACM) is a plugin framework and the plugin is running in the Event Server. The plugin framework only exists as part of the MIP Library, no other options.
