Ptz command in component SDK is blocking
When we tried to send the PTZ command to the camera, the call is getting blocked randomly. After that, the stop commands are failing as well.
double pan = 0.0, tilt = 0.0, zoom = 0.0, panSpeed = 0.5, tiltSpeed = 0.5, zoomSpeed = 0.5;
    switch (action)
      case "Z+":
        zoom = 1.0;
        break;
      case "Z-":
        zoom = -1.0;
        break;
      case "R":
        pan = 1.0;
        break;
      case "L":
        pan = -1.0;
        break;
      case "U":
        tilt = -1.0;
        break;
      case "D":
        tilt = 1.0;
        break;
      case "STOP":
        zoom = 0.0;
        pan = 0.0;
        tilt = 0.0;
        break;
PTZMoveStartCommandData2 data = new PTZMoveStartCommandData2()
        Pan = pan,
        Tilt = tilt,
        Zoom = zoom,
        PanSpeed = panSpeed,
        TiltSpeed = tiltSpeed,
        ZoomSpeed = zoomSpeed
EnvironmentManager.Instance.SendMessage(
    new Message(MessageId.Control.PTZMoveStartCommand, data), \_camera.FQID);
What has to do to make it work properly? Any way to debug why it hangs?
Can you please test if unmodified PTZ and Presets sample works properly?
https://doc.developer.milestonesys.com/html/index.html?base=samples/componentsamples/ptzandpresets/readme.html&tree=tree_2.html
