I am developing a plugin that will be performing PTZ based operations and would like to use the same PTZ control used in the SmartClient for camera views. Is this control available in the PTZ or elsewhere?
Thanks,
John Moody
Thanks,
John Moody
Correction, Is this winform control available in the SDK or elsewhere?
No, the Smart Client control is internal and not exposed. You might be able to design your own control to look like what you find in the Smart Client.
Thanks for the information.
John
Please pick a best answer so that the question is “solved”. (Right now shows up as unsolved.)
