READ AUDIT, SYSTEM OR RULE LOGS via MIP protocol integration
Hi Milestone,
Is it possible to get the related logs from Xprotect via protocol integration?
We wants to show the logs in the customized web interface.
I found a sample via component integration but no related information in Soap.
Could you please help it?
Best regards,
allen
Hi Milestone,
I found the sample based on component integration, but no related information in Protocol integration.
https://developer.milestonesys.com/s/article/read-Audit-System-or-Rule-logs-from-the-MIP-SDK
Is it possible to get audit log or system log based on Soap protocol?
Could you help provide the related information?
Best regards,
Allen
Hi Allen,
At the moment, it’s not supported. But we will consider making this available in one of the future releases.
Best regards,
Milos
