We decided try to use the message “Milestone” and faced with a problem of recieve messages on the side of “EventServer” plug-in.
Event Server plug-in code (BackgroundPlugin.cs):
public class EmptyMessageIdFilter : MessageFilter
private string _filter;
public EmptyMessageIdFilter(string messageId = null)
_filter = messageId;
public override bool Match(Message message, FQID destination, FQID sender)
return true;
public override void Init()
_regEvents = new List<object>();
_messageCommunication = MessageCommunicationManager.Get(EnvironmentManager.Instance.MasterSite.ServerId);
foreach (string evt in Properties.Settings.Default.MessageIds)
_regEvents.Add(_messageCommunication.RegisterCommunicationFilter(EventHandler, new CommunicationIdFilter(evt)));
_msgRef = EnvironmentManager.Instance.RegisterReceiver(EventHandler, new EmptyMessageIdFilter());
_msgRef2 = EnvironmentManager.Instance.RegisterReceiver(EventHandler, new MessageIdListFilter(Properties.Settings.Default.MessageIds.Cast<string>().ToArray()));
private object EventHandler(Message message, FQID f1, FQID f2) // Don't recieve message with ID from MessageID list
return null;
Event Server plug-in code (Definition.cs):
public override List<string> PluginDefinedMessageIds
get
return Properties.Settings.Default.MessageIds.Cast<string>().ToList();
However, in other systems approach works fine.
SomeSystem handle and send message code:
public delegate void XProtectEvent(string EventName, string Data);
public static event XProtectEvent OnXProtectEvent; private Dictionary<string, object> _inputEvents;
private MessageCommunication _messageCommunication;
public static void Connect(string EventServerHostname, string user, string passwd, List<string> inEvents)
try
VideoOS.Platform.SDK.Environment.Initialize();
Uri uri = new UriBuilder(EventServerHostname).Uri;
VideoOS.Platform.SDK.Environment.AddServer(uri, new NetworkCredential(user, passwd));
VideoOS.Platform.SDK.Environment.Login(uri);
_instance._messageCommunication = MessageCommunicationManager.Get(EnvironmentManager.Instance.MasterSite.ServerId);
foreach(string evt in inEvents)
_instance._inputEvents[evt] = _instance._messageCommunication.RegisterCommunicationFilter(XProtectEventHandler, new CommunicationIdFilter(evt));
Driver.Log("Subscribed to Milestone XProtect event {0} at {1}", evt, EventServerHostname);
catch (Exception e)
Driver.Log(LogType.Error, e.ToString());
private static object XProtectEventHandler(Message message, FQID destination, FQID sender)
if (OnXProtectEvent != null && !String.IsNullOrEmpty((String)message.Data))
OnXProtectEvent(message.MessageId, (String)message.Data);
return new object();
public static bool SendEvent(string EventName, string EventData)
bool IsSucces;
if (String.IsNullOrEmpty(EventName) || String.IsNullOrEmpty(EventData))
return false;
try
_instance._messageCommunication.TransmitMessage(new VideoOS.Platform.Messaging.Message(EventName, EventData), null, null, null);
IsSucces = true;
catch (Exception e)
Driver.Log(LogType.Error, e.Message);
IsSucces = false;
return IsSucces;
Two our systems perfectly communicate with each other in this way.
For SDK we created a sample user in Windows (non-participating in windows groups), created role in milestone and add this user in milestone with created role
What could be the problem?
