I’m trying to retrieve the device status from a Milestone XProtect Recording Server (version 23.2a) using the legacy SOAP service: /RecorderStatusService/RecorderStatusService2.asmx
Here’s my current flow:
- I call ServerAPI/ServerCommandService.asmx, and create a new token (the call succeeds).
- I use that token together with the device ID I found through /ServerAPI/ServerCommandService.asmx to call /recorderstatusservice/recorderstatusservice2.asmx
- The response I get is:
HTTP/1.1 500 Internal Error
Server: XProtect Recording Server 23.2a
<soap:Fault>
<soap:Reason>
<soap:Text xml:lang="en">Token invalid</soap:Text>
</soap:Reason>
<detail>
<ErrorNumber>20001</ErrorNumber>
<SubErrorNumber>2</SubErrorNumber>
</detail>
</soap:Fault>
I’m using a brand-new token, but the server still rejects it.
The token is sent as part of the SOAP body.
Question:
Can anyone explain what might be wrong with my request, or why I’m getting a “Token invalid (20001/2)” error even with a freshly created token?
