Recording storage - sdk 2016R2
In the latest SDK (2016R2) there is a new functionality :
The Configuration API has been expanded to support management of Recorder Storage.
But I can’t find any documentation/sample about this new functionality also using the search button in MIP Documentation.
Can you help me with a sample that explain the class and method involved in this new functionality.
Thanks.
The Configuration API Client sample can show you.
When you mark a Recording Server node you will see defined storages, you might overlook this at first as you might have to scroll the right hand side where the info turns up.
