Relogging smart client user if server stops working
I’m trying to write a script where pc with smart client would watch server pc with management client and if that server stops working, I need it to relog to copy pc server with another adress and keep doing it’s work.
I tried using python protocol examples and tried to see if it’s possible with api but I found no suitable method for my needs.
The script could run the Smart Client using startup parameters or script.
Try in a command prompt to do a
client.exe -help
If you have further questions about starting the Smart Client using parameters please ask in the support community. (Using the client this way is not really a SDK related question.)
