Resizing image viewer control causes coretoolkits crash with cx0005 error?
Is there a supported way to enlarge image viewer control? Maximize? If you maximize minimize 2 or 3 times the camera will disconnect and the app will crash. We are displaying 12 controls and maximize will enlarge one to cover the others. We are using the 32 bit version of r18. We updated the video drivers.
I have built the VideoViewer sample in 32 bit, I have then minimized, maximixed and resized many times but I am unable to reproduce the issue.
Can you reproduce the issue in your setup using the VideoViewer sample unmodified?
If you use another client PC does the same thing happen? (different hardware / different setup)
If you use another test camera does the same thing happen?
