REST API Alarm Sessions: Filtering by "modified" causes 400 Bad Request when new alarm arrives
Hi ,
I am encountering a severe and highly reproducible backend issue when polling for alarms via the REST API (/api/rest/v1/alarmSessions/{id}/alarms).
When registering an alarm session, if I apply a filter using the "time" target, everything works flawlessly. However, if I change the target to "modified", the API abruptly drops the connection with a 400 Bad Request the exact moment a new alarm is triggered or modified.
Steps to Reproduce:
  1. Register the Session: I register an alarm session with the following payload, filtering by modified:
JSON
    "filterBy": [
            "operator": "gt",
            "target": "modified",
            "value": "2026-03-06T05:50:00.002Z"
    "orderBy": [
            "direction": "asc"
  1. Start Polling: I poll the session’s /alarms endpoint every 10 seconds.
  2. Initial Responses (Working): As long as there are no new or modified alarms in the system, the server correctly responds with a 200 OK and the empty structure:
JSON
{"deletedFromSession":[],"addedToSession":[],"updatedInSession":[]}
  1. The Crash: The moment a new alarm arrives in XProtect (or an existing one is modified), the very next polling request instantly fails.
    • Status: 400 Bad Request
    • Body: 0 bytes (Empty)
You do not mention the version you are using, please let us know. Is this on XProtect VMS version 2025R3?
We are using 2024 R2
I reproduced your observations using 2025R3 and have reported it to Milestone Development. I will let you know what they find.
That works, thank you.
Milestone Development have developed a patch for the 2025R3 Event Server. Please find it here.
