Rest API gateway for 2021R1
Hi, can i get rest API gateway installer for for 2021R1? Thanks.
Unfortunately the Rest API is first introduced in 2021 R2. In 2022 R1 and newer it is an integrated part of the XProtect VMS and no extra install is required.
There is no Rest API in older versions and your rest api application will require that you persuade your customer to upgrade.
https://doc.developer.milestonesys.com/html/index.html?base=gettingstarted/mip2022r1_intro.html&tree=tree_home.html
noted and thanks Rie!
