I would like to get a suggestion on how to retrieve the state of an HW-input (for example and input on an ADAM module) with a syncronous call. I cannot find any samples showing this.
One possible alternative (which is not prefered in our scenario) is to do a request for all statuses sending the MessageCommunication.ProvideCurrentStateRequest message and picking up the response. When using the “ProvideCurrentStateRequest-approach”, the list of items contain the inputs wanted. However, the value is “Input changed”, as opposed to “Input Activated”.
I guess the problem is more or less the same as this: https://developer.milestonesys.com/s/question/0D50O00003GYFFvSAP/inputoutput-event-handling
Milestone Development made fix for MIP SDK 2019R2, so that the Event Server ignore Output Changed event as it always come right after the much more describing Activated/Deactivated event.
The fix was not mentioned in the documentation. What is worse is the the same issue exists for inputs and was not fixed. I will make a new bug report on this.
I had an idea that the same information would be easier to get using the Status API, and I think it is. It is important to note that the Status API does not work with e-code, only c-code (XProtect Corporate, Expert and all Plus products). My snippet of code (console application):
class Program
const string URI = "http://localhost";
const string USER = "";
const string PASSWORD = "";
const string AUTH = "Negotiate";
const string GUIDSTRING = "BB96F126-E702-4305-942E-CC974DC487C9";
static void Main(string[] args)
VideoOS.Platform.SDK.Environment.Initialize();
if (Login())
VideoOS.Platform.Login.LoginSettings loginSettings = VideoOS.Platform.Login.LoginSettingsCache.GetLoginSettings(EnvironmentManager.Instance.CurrentSite);
Guid inputGuid = new Guid(GUIDSTRING);
Item inputItem = VideoOS.Platform.Configuration.Instance.GetItem(inputGuid, Kind.InputEvent);
VideoOS.Platform.SDK.Proxy.Status2.RecorderStatusService2 client = new VideoOS.Platform.SDK.Proxy.Status2.RecorderStatusService2(inputItem.FQID.ServerId.Uri);
VideoOS.Platform.SDK.Proxy.Status2.Status status = client.GetCurrentDeviceStatus(loginSettings.Token, new Guid[] { inputGuid });
string ioStateString = status.InputDeviceStatusArray.FirstOrDefault().State.ToString();
Console.WriteLine("Input: " + inputItem.Name + " is " + ioStateString);
Console.WriteLine("");
Console.WriteLine("Press any key");
Console.ReadKey();
static private bool Login()
Uri uri = new UriBuilder(URI).Uri;
CredentialCache cc = VideoOS.Platform.Login.Util.BuildCredentialCache(uri, USER, PASSWORD, AUTH);
VideoOS.Platform.SDK.Environment.AddServer(uri, cc);
// You need this to apply Enterprise "basic" credentials.
//CredentialCache cc = VideoOS.Platform.Login.Util.BuildCredentialCache(uri, "test", "test", "Basic");
// The BuildCredentialCache can aslo build credential for Windows login ..
//CredentialCache cc = VideoOS.Platform.Login.Util.BuildCredentialCache(uri, "myserver\\testuser", "Str0ngPa$", "Negotiate");
// For reuse of Windows credentials ..
//CredentialCache cc = VideoOS.Platform.Login.Util.BuildCredentialCache(uri, "", "", "Negotiate");
try
VideoOS.Platform.SDK.Environment.Login(uri);
catch (VideoOS.Platform.SDK.Platform.ServerNotFoundMIPException snfe)
Console.WriteLine("Server not found: " + snfe.Message);
VideoOS.Platform.SDK.Environment.RemoveServer(uri);
return false;
catch (VideoOS.Platform.SDK.Platform.InvalidCredentialsMIPException ice)
Console.WriteLine("Invalid credentials for: " + ice.Message);
return false;
catch (Exception)
Console.WriteLine("Internal error connecting to: " + uri.DnsSafeHost);
return false;
Console.WriteLine("Login succeeded.");
return true;
On a final note. The input has the state “Unknown” until the first time the input has been used, this is a known limitation of the XProtect recording server.
