Retrieve Camera Codec Stream through Protocol Integration (other than Configuration API Service)
We are using protocol integration through a Java client.
So we cannot use ConfigurationApiService due to security restriction (wsHttpBinding client does not exist in Java).
We are using ServerCommandService with GetConfiguration SOAP Method.
The codec is not returned in this method.
Is it possible to retrieve Codec Stream of camera through Protocol Integration ?
I am not sure the two SOAP services you mention are different.
https://doc.developer.milestonesys.com/html/index.html?base=gettingstarted/intro_soap_protocols.html&tree=tree_3.html
The RestAPI generally offers the same information as the Configuration API, maybe it will be a better solution for you.
https://doc.developer.milestonesys.com/mipvmsapi/
https://doc.developer.milestonesys.com/mipvmsapi/api/config-rest/v1/
