I am trying to use RawVideoSource and RawLiveSource classes but I get exceptions when I call Init method :
L’exception System.Exception n’a pas été gérée
HResult=-2146233088
Message=Not Implemented in this Environment
Source=VideoOS.Platform
StackTrace:
à VideoOS.Platform.Util.InternalCommandService.ImageExporterConnect(FQID deviceFQID, String media, Boolean requestSignatures)
à VideoOS.Platform.Data.RawVideoSource.Init()
à CameraStreamResolution.Program.GetRes() dans [C:\\ESI\\GIT\\R1Protocols\\Src\\Milestone\\lastSDK\\MIPSDK\\ComponentSamples\\CameraStreamResolution\\Program.cs](file:C:/ESI/GIT/R1Protocols/Src/Milestone/lastSDK/MIPSDK/ComponentSamples/CameraStreamResolution/Program.cs):ligne 268
à CameraStreamResolution.Program.Main(String\[\] args) dans [C:\\ESI\\GIT\\R1Protocols\\Src\\Milestone\\lastSDK\\MIPSDK\\ComponentSamples\\CameraStreamResolution\\Program.cs](file:C:/ESI/GIT/R1Protocols/Src/Milestone/lastSDK/MIPSDK/ComponentSamples/CameraStreamResolution/Program.cs):ligne 70
L’exception VideoOS.Platform.MIPException n’a pas été gérée
HResult=-2146233088
Message=Could not connect to server
StackTrace:
à VideoOS.Platform.Live.RawLiveSource.Init()
à CameraStreamResolution.Program.GetResLive(Guid streamid) dans [C:\\ESI\\GIT\\R1Protocols\\Src\\Milestone\\lastSDK\\MIPSDK\\ComponentSamples\\CameraStreamResolution\\Program.cs](file:C:/ESI/GIT/R1Protocols/Src/Milestone/lastSDK/MIPSDK/ComponentSamples/CameraStreamResolution/Program.cs):ligne 387
à CameraStreamResolution.Program.GetDefaultStream() dans [C:\\ESI\\GIT\\R1Protocols\\Src\\Milestone\\lastSDK\\MIPSDK\\ComponentSamples\\CameraStreamResolution\\Program.cs](file:C:/ESI/GIT/R1Protocols/Src/Milestone/lastSDK/MIPSDK/ComponentSamples/CameraStreamResolution/Program.cs):ligne 322
à CameraStreamResolution.Program.Main(String\[\] args) dans [C:\\ESI\\GIT\\R1Protocols\\Src\\Milestone\\lastSDK\\MIPSDK\\ComponentSamples\\CameraStreamResolution\\Program.cs](file:C:/ESI/GIT/R1Protocols/Src/Milestone/lastSDK/MIPSDK/ComponentSamples/CameraStreamResolution/Program.cs):ligne 72
I have used the SDK 2017 R1, my VMS are :
- Milestone XProtect Enterprise 8.1a (96231)
and
- Xprotect Corporate 2014 Test
The Jpeg equivalent are OK ie JPEGLiveSource and JPEGVideoSource.
I notice also that I am not able to retrieve stream when I am using StreamDataSource.
