I’m working with a developer for a company called Asti, we are trying to integrate a radio stream from their server software (Voisus) via an RTP stream using the universal driver. On the Voisus side we see the connection made and receive a DESCRIBE command and send a response. After the response is sent, the Milestone closes the TCP connection.
I’m not sure why it reports the connection failed.
Also worth noting that it works just fine with VLC player. But not sure whether the problem is with the network connection somehow, or with the response to the DESCRIBE command.
Any information that I could provide to the developer to help make this RTP stream work would be much appreciated.
