RTSP and Onvif Bridge Services Will not start
The RTSP and Onvif Bridge services will not start - the services hang with the status “starting” and there is nothing in the logs. The services worked when I initially installed the system. Does anyone know of any troubleshooting steps I can take? All the other services seem to be working correctly as far as I can tell. I am running the corporate version with a trial license.
Have you seen and used - https://developer.milestonesys.com/s/article/ONVIF-Bridge-installation-and-setup-detailed-guide
