SaveItemConfiguration in our smart client plugin. Possible?
I know the docs say not available in SC but I thought that because I was specifying the serverId maybe it would work.
code:
try { Configuration.Instance.SaveItemConfiguration(anotherServerID, ThePluginId, currentItem);}
we’re getting:
VideoOS.Platform.ArgumentMIPException: Server with serverId not found
at VideoOS.Platform.ConfigurationItems.IConfigurationChildItem..ctor(ServerId serverId, String path)
at VideoOS.Platform.Configuration.SaveItemConfiguration(ServerId serverId, Guid pluginDefinitionId, Item item)
Since 2018 R3 SaveItemConfiguration should also work in Smart Client (documentation is unfortunately outdated), but the serverId must be for either a Management or Recording Server known by the Smart Client.
The error you are getting indicates that this is not the case with the one you are using.
great to hear.
I have tried to use both
anotherServerID = EnvironmentManager.Instance.MasterSite.ServerId;
anotherAnotherServerId = EnvironmentManager.Instance.CurrentSite.ServerId;
but in our try/catch we got: VideoOS.Platform.ArgumentMIPException: Server with serverId not found
the return from anotherServerID.ServerHostname is the ip(in the SC login we added ip:port for the server, along with basic auth and our user/pass that we created) for our Enterprise(non plus) 2019 R1 recording server.
How can I get the server when we’re in our SC plugin?
as a precaution we updated to the latest videoos set of dlls and files.
no changes in the exception message
ServerId thedangserverid = EnvironmentManager.Instance.MasterSite.ServerId;
Configuration.Instance.SaveItemConfiguration(thedangserverid,RookArchiveDefinition.RookArcivePluginId, currentItem);
2019-Sep-13 16:16:58,704 [Main Thread.][SaveJobConfiguration] ERROR -
at OurArchive.Admin.OurItemManager.SaveJobConfiguration(Item currentItem, Job job) in [D:\sources\Aug15](file:D:/sources/Aug15) 0855 sep13\OurArchive\Admin\OurItemManager.cs:line 344
Sorry. I was not aware that you were running on eCode (non-plus) products. For these products it is unfortunately correct that the SaveItemConfiguration method is not supported in the Smart Client.
