I’m reaching out regarding a compatibility issue we’re experiencing with our iSentry application deployed as a Milestone MIP plugin.
Issue Description
When our plugin, built against the 2024 SDK, attempts to connect to a Milestone VMS running the 2021 version, the Management Client crashes upon accessing our plugin’s configuration tab.
The following error is displayed:
Method not found: Boolean VideoOS.Platform.FQID.op_Equality(VideoOS.Platform.FQID, VideoOS.Platform.FQID)
Analysis
We believe this occurs because the VideoOS.Platform.FQID.op_Equality() method is not present in the 2021 SDK, but our application was compiled against the 2024 SDK where this method appears to exist. This creates an incompatibility at runtime when the plugin tries to execute code that relies on this operator.
Context
We’re working in a mixed-version environment where we need to support both older (2021) and newer (2025) Milestone VMS installations. Our current build approach uses a single plugin binary compiled against the 2024 SDK.
Questions
- Is there a recommended approach for supporting multiple Milestone VMS versions with a single MIP plugin?
- Should we maintain separate builds compiled against each target SDK version? This is really difficult for us because it will mean to maintain two main versions.
- Could you help clarify when the op_Equality() operator was introduced to the FQID class? This would help us understand the scope of potential compatibility issues.
- Are there any guidelines or documentation on SDK compatibility across different Milestone releases that we should review?
We appreciate any guidance you can provide on the proper approach for cross-version compatibility.
Thank you for your time.
Pablo.
