I have implemented the “GetStatusCommand” but it is causing some temporal errors. If I try many times, it works once or twice but it also fails. Always, I am trying with the same code developed in PHP.
Please, find below the log messages:
- Error:
joaquin@joaquin-lap-linux:~/PhpstormProjects/LPRManager$ php bin/console integrations:milestone STATUS
08:56:06 ERROR [app] Get Server Status: Ko. Milestone login error. Milestone Error Code: 19
08:56:06 ERROR [app] Milestone Disconnect: Ko. Milestone login error. Milestone Error Code: 19
[WARNING] Command Name: "GetServerStatus" | Result: "Error" | Error Code: "19"
08:56:06 WARNING [app] 2022-11-30T08:56:06+01:00-Milestone Command: KO. Milestone command executed with errors. Start time: 2022/11/30 08:56:05. End time: 2022/11/30 08:56:06. Details: Command Name: "GetServerStatus" | Result: "Error" | Error Code: "19"
- After that a new attempt:
[SUCCESS] Command Name: "GetServerStatus" | Result: "OK" |
The workflow to make the request is:
- Connect and get public key from server.
- Calculate shared key and encrypt credentials. Login successfully.
- Execute “RequestChallengues”.
- If success, store the challengues and use to request server status (to test) using “GetServerStatus” command.
- Once getting the result or the error, proceed to disconnect from server.
Please, could you help us? We are using versión 2022 R1
Thank you. Best regards,
Joaquín
