Thank you for the feedback!
If I run the Recording Server without the driver, it keeps on running for days, and the moment I load the driver it breaks within about 15 hours.
I have gathered some logs from two files in the recording server logs, does this shed any light? I am at a bit of a loss how this happens. The device is setup as a hardware device with channels, it shows live and recorded video and audio. I pull the footage from the device as connectivity is intermittent and footage gets stored after the fact, not immediately.
I set it up by first developing the video live view, then playback, then live audio, and playback audio is still outstanding.
The audio streams were added after the fact and I did “update hardware” to load the audio playback ability after I changed it to on-board storage of audio.
Security token file:
2025-07-18 06:37:39.758+02:00 [ 523] WARNING - Token verify failed: Unavailable
2025-07-18 06:37:39.877+02:00 [ 39] INFO - Requested token from server
2025-07-18 06:37:39.877+02:00 [ 39] WARNING - Token requested from server is unavailable
2025-07-18 06:37:39.877+02:00 [ 39] INFO - Token added (6)
2025-07-18 06:37:39.877+02:00 [ 603] WARNING - Token verify failed: Unavailable
2025-07-18 06:37:39.898+02:00 [ 39] INFO - Requested token from server
2025-07-18 06:37:39.898+02:00 [ 39] WARNING - Token requested from server is unavailable
2025-07-18 06:37:39.898+02:00 [ 39] INFO - Token added (6)
And the other log file:
2025-07-18 06:47:35.468+02:00 [ 39] INFO - GetSecurityToken Token
2025-07-18 06:47:35.488+02:00 [ 39] INFO - GetSecurityToken Token
2025-07-18 06:47:37.802+02:00 [ 374] ERROR - HttpRequestException - The SendAsync request message failed: An error occurred while sending the request.
