Hi All,
Relying on the code of the plugin “SCHotSpot”, I developed a plugin that uses the SelectedCameraChangedIndication event.
When I select a camera in a view in the main smartclient window, the event is invoked.
When I select a camera in a view in a floating window, the event is not triggered.
I have the same problem when I send the view in a new window and then select a camera in this new windows.
The code used is:
EnvironmentManager.Instance.RegisterReceiver(new MessageReceiver(ViewItemSelected),new MessageIdFilter(MessageId.SmartClient.SelectedCameraChangedIndication));
Do I have to use another event?
Or is there another way to trigger the event even on the secondary windows?
Thanks in advance
