Manual shows the below about SelectedViewChangedIndication .
SelectedViewChangedIndication = “SmartClient.SelectedViewChangedIndication” Send by the Smart Client when a view has changed. The Data field contains the ViewAndLayoutItem for the new view, or null when a floating or secondary window is being closed. The sender FQID contains the id for the window, e.g. null for main window, otherwise a specific FQID.
When view button is clicked FQID is not null. Does the manual correct?
SC send the following data
Server:SC:localhost
ObjectId:15da80d4-7595-431f-9866-674d2b80acc5,
Type:15da80d4-7595-431f-9866-674d2b80acc5
