Send custom data to a generic event
Hi
My end goal is to trigger an event in Milestone from our application (OutWatch). Our application gets incoming alarms from multiple cameras that includes images/video. I want to trigger an alarm in Milestone and include the images/videos URLs so that they will be displayed (or at least show as links to the operator so he can click them to see)
so I created under “genric events” a new “AlertFromOutWatch”
I then called GET http://sensodev/api/rest/v1/eventtypes, found the above item (for some reason in the response json it appeared under “user defined events”).
then I sent this:
POST http://sensodev/api/rest/v1/events with the proper authorization header
With this body:
“type”: “93418786-63c7-44b4-9e5c-0c45cbdae13d”, – this is from the prev GET call
“source”: “UserDefinedEvent”, – here i tried null/nothing/empty string
“data”: {
“snapshots”: [
https://sensoguard-trailcam-images.s3.eu-west-1.amazonaws.com/1/1/0A2D7C1A-6283-412B-89B8-FC88272C4220.jpg”,
https://sensoguard-trailcam-images.s3.eu-west-1.amazonaws.com/1/1/0A6A0159-5A3B-40EA-8155-F4D7AF771186.jpg
I get “unknown source…”, or “A source is required for the given event type"
I understand this is supposed to be a camera id – but I am not a camera – I am an external event trigger
This is where I am stuck right now.
Generic event have a special purpose, for what you are doing make sure to use user-defined events.
Hi
thank you for your answer -
if so, how do I send my image/video URLs? (the docs state that "User defined events do not support ‘data’ and ‘datatype’)
Then use Analytics Events. I had an idea that User-defined events did support this, but I am absolutely sure Analytics Events does.
hello again
i created a new analytics event, found it’s id and put it in the “type”. what comes in “source”?
i tried “InputEvent” - but got “Unknown source or invalid source format, retrieve valid sources from the configuration API” - it expects a camera id here? but the trigger is an external application, not camera…
“type”: “e04a952b-418a-429c-bde5-752757842ebd”,
“source”: “InputEvent”,
“data”: {
"snapshots": \[
  "[https://sensoguard-trailcam-images.s3.eu-west-1.amazonaws.com/1/1/0A2D7C1A-6283-412B-89B8-FC88272C4220.jpg](https://sensoguard-trailcam-images.s3.eu-west-1.amazonaws.com/1/1/0A2D7C1A-6283-412B-89B8-FC88272C4220.jpg)",
  "[https://sensoguard-trailcam-images.s3.eu-west-1.amazonaws.com/1/1/0A6A0159-5A3B-40EA-8155-F4D7AF771186.jpg](https://sensoguard-trailcam-images.s3.eu-west-1.amazonaws.com/1/1/0A6A0159-5A3B-40EA-8155-F4D7AF771186.jpg)"
thanx
The source is described in the Introduction here - https://doc.developer.milestonesys.com/mipvmsapi/api/events-rest/v1/#section/Introduction
Source
The event source is the item where the event originated. For example, a camera. You can list all cameras with the Configuration REST API: Cameras.
hello again
I hope ill make my case clear this time:
our company has an application that manages incoming images and videos from cameras.
I am the developer of this application.
we want to add integration to Milestone - such that our application will trigger an incoming alarm in Milestone AND send some data into that trigger (for start - some URLs of the images/videos)
Please read the whole case conversation above - I tried everything you suggested, and I wrote the actual data i am trying to send and the results I get back
  1. the triggering “source” is our application - NOT a camera
  2. we need to be able to send data along with the event/alarm
  3. if you can - give me a request example that fits our case, with all its parameters and where to get them from
  4. if it’s possible - we can have a short online session so I can show you what Im doing
thank you,
Erez
Here is an example the works for me.
POST https://localhost/api/rest/v1/events
Body
  "type": "56d42c26-62aa-489a-bfef-1867970bda63",
  "source": "cameras/dacc7b2c-b819-4ddf-9d45-f4699fa342da",
  "datatype": "analytics",
  "tag": "My custom tag",
  "data": {
    "snapshots": [{ "image": "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" }]
