Send message to SensorMonitor Sample from ComponentIntegration
// SensorMonitor Sample has uses this listener:
public override void Init()
     msgRef = EnvironmentManager.Instance.RegisterReceiver(TriggerReceiver, new
            MessageIdFilter(MessageId.Control.TriggerCommand));
HOW DO I … send or post this message, to change the Icon:
to be received by SensorMonitor’s TriggerReceiver() ? Do I need to knwo the FQID dest, or FQID sender?
TriggerReceiver(VideoOS.Platform.Messaging.Message message, FQID dest, FQID sender)
“message”: {
“MessageId”: “Control.TriggerCommand”,
“RelatedFQID”: {
“ServerId”: {
"Type": "XPCO",
"Hostname": "easynvr-01",
"Port": 443,
"Id": "9d51cc29-4f28-4522-b85e-61457a17b532",
"Scheme": "https"
“ParentId”: “b9412d8a-a00d-484b-9693-3c1a2ed41ded”,
“ObjectId”: “6c341472-ab91-4630-a015-a8e940dfdbb4”,
“FolderType”: 0,
“Kind”: “0375137e-3136-445d-add1-f855d4be1b44”
“Data”: “PH_MASKNOTDETECTED”,
“Reason”: “UserAction”,
“ExternalMessageSourceEndPoint”: null
“dest”: {
“ServerId”: {
“Type”: “XPCO”,
“Hostname”: “easynvr-01”,
“Port”: 443,
“Id”: “9d51cc29-4f28-4522-b85e-61457a17b532”,
“Scheme”: “https”
“FolderType”: 0,
“sender”: {
“ServerId”: {
“Type”: “XPCO”,
“Port”: 80,
“Scheme”: “http”
“ObjectIdString”: “S-1-9-2374562217-701256093-676274757-3093193029-2048374066-1-4107724087-1800141127-2739864504-80127112”,
“FolderType”: 0,
“Kind”: “e18c7649-3d38-45dc-9ce1-b0dd06e77b24”
Currently SensorMonitor sample only listens for messages sent locally in the Event Server (using EnvironmentManager.Instance.RegisterReceiver). I know those messages are coming from map/smart map in Smart Client, but that communication is done by a non-public API and then retransmitted internally in the Event Server.
To be able to send similar messages from a component integration you should use MessageCommunication, which means that the plug-in also needs to be extended to listen using this in addition to the local listening. Have a look at the Chat sample for an example on how to use MessageCommunication: https://doc.developer.milestonesys.com/html/index.html?base=samples/pluginsamples/chat/readme.html&tree=tree_1.html
