Hello everyone, ![]()
I currently have a powershell script that allows you to restart the Milestone services while writing the status format .txt from windows it works, but now I would like to send the results of the .txt file to the Alarm Manager - SmartClient.
If there is another simpler solution, I am listening ![]()
You will find my code below
param (
# Specifies the service name
#[Parameter(Mandatory = $true)]
#string$serviceName = '',
# Specifies the directory for the log file
[Parameter(Mandatory = $false)]
[string]$logPath = 'C:\Scripts\Logs',
# Specifies the max number of service Start attempts per run
[int]$maxTries = 3,
# Specifies the number of seconds to wait before trying again after a failed start attempt or before rechecking a Pending status
[int]$secondsBeforeRetry = 30
$list_ServiceMilestone = @("MilestoneEventServerService","Milestone XProtect Data Collector Server","Milestone XProtect Log Server","Milestone XProtect Management Server","Milestone XProtect Mobile Server","Milestone XProtect Recording Server")
foreach ($serviceName in $list_ServiceMilestone){
$logName = $serviceName + '_log.txt'
try {
$service = Get-Service $serviceName -ErrorAction Stop
catch {
Write-Host 'Cannot find any service with service name:' $serviceName
$logFullPath = Join-Path -Path $logPath -ChildPath $logName
if(!(Test-Path -Path $logFullPath)) {
$timestamp = (Get-Date -Format yyyy-MM-dd--HH-mm-ss)
New-Item -Path $logPath -Name $logName -ItemType "file" -Value "## Log file for $serviceName auto-start script ##`n## Created [$timestamp] ##`n" -Force
Start-Sleep -s 1
if ($service.Status -eq 'Stopped') {
$tries = 0
while (($tries -lt $maxTries) -and ($service.Status -ne 'Running')) {
if ($tries -eq 0) {
$logSvcStoppedMsg = "[$timestamp] $serviceName service status is $($service.Status), attempting to Start. Will try up to $maxTries times."
Add-Content -Path $logFullPath -Value $logSvcStoppedMsg
try {
Start-Service $serviceName -ErrorAction Stop # Throws exception if command fails, for example if the service is Disabled
$tries += 1
Start-Sleep -s 10
$service.Refresh()
if ($service.Status -eq 'Running') {
$logSvcStartSuccessMsg = "[$timestamp] Attempt #$tries - $serviceName service status is now $($service.Status)"
Add-Content -Path $logFullPath -Value $logSvcStartSuccessMsg
catch {
$errorMsg = $_
$tries += 1
Start-Sleep -s 10
$service.Refresh()
$logSvcStartExceptionMsg = "[$timestamp] Attempt #$tries - $serviceName service status is $($service.Status) and failed to start with error:`n $errorMsg"
Add-Content -Path $logFullPath -Value $logSvcStartExceptionMsg
if ($tries -ne $maxTries) {
Start-Sleep -s $secondsBeforeRetry
$service.Refresh()
if (($service.Status -eq 'StartPending') -or ($service.Status -eq 'StopPending')) {
$maxStateChecks = 3
$stateChecks = 0
while (($stateChecks -lt $maxStateChecks) -and (($service.Status -eq 'StartPending') -or ($service.Status -eq 'StopPending'))) {
$logSvcStillPendingMsg = "[$timestamp] Attempt #$tries - $serviceName service status is $($service.Status). This may indicate the service is hung in the Starting or Stopping state. Waiting another $secondsBeforeRetry seconds before checking again."
Add-Content -Path $logFullPath -Value $logSvcStillPendingMsg
$stateChecks += 1
if ($stateChecks -ne $maxStateChecks) {
$service.Refresh()
} elseif ($service.Status -eq 'Stopped') {
$logSvcStoppedAfterPendingMsg = "[$timestamp] Attempt #$tries - $serviceName service status is now $($service.Status). If any Start attempts remain the script will try again on the next loop."
Add-Content -Path $logFullPath -Value $logSvcStoppedAfterPendingMsg
$service.Refresh()
if (($stateChecks -eq $maxStateChecks) -and (($service.Status -eq 'StartPending') -or ($service.Status -eq 'StopPending'))) {
$logSvcStuckPendingMsg = "[$timestamp] Attempt #$tries - $serviceName service status appears stuck in a Pending (Starting or Stopping) state. Attempting to force kill process."
Add-Content -Path $logFullPath -Value $logSvcStuckPendingMsg
$servicePID = Get-CimInstance -Class Win32_Service -Filter "Name LIKE '$serviceName'" | Select-Object -ExpandProperty ProcessId
$resultMsg = taskkill /pid $servicePID /f
$logSvcTaskKillMsg = "[$timestamp] Attempt #$tries - taskkill result:`n $resultMsg"
Add-Content -Path $logFullPath -Value $logSvcTaskKillMsg
Start-Sleep -s 10
$service.Refresh()
$logSvcStatusMsg = "[$timestamp] Attempt #$tries - $serviceName service status is now $($service.Status)"
Add-Content -Path $logFullPath -Value $logSvcStatusMsg
if (($tries -eq $maxTries) -and ($service.Status -ne 'Running')) {
$logNoMoreAttemptsMsg = "[$timestamp] $serviceName service status is $($service.Status) after $maxTries Start attempts. This run of the script will not continue trying to Start the service."
Add-Content -Path $logFullPath -Value $logNoMoreAttemptsMsg
# Add line break at end of log file entry
Add-Content -Path $logFullPath -Value "`n"
