I’ve just installed XProtect Expert 2017 and i can’t find the “server access” tab anymore in order to configure the local port.
Thank you in advance for any help you can provide.
This is a question suited for the Milestone Support Community.
There is no answer to that question in the link.Any one find the solution? Is there any documentation about it?
It sounds like you’ve come from the Professional VMS product to the Advanced VMS product range. There is no such configuration area for the Advanced VMS range. Changing the HTTP port for the management server is a bit more complicated but there’s a KB on it I believe.
