Is it possible to implement a plugin started by the event server that works independently of SC e MC but accessible to MC for parameters configuration?
Many Thanks,
Freddy
Many Thanks,
Freddy
Yes, you can. There are more than one sample that does this. ServerSideCarrousel sample might be interesting for you.
Rie,
thank you for your answer.
To be sure to understand I will ask you some questions related to the ServerSideCarrousel example:
Many Thanks,
Freddy
if you create a new plugin using the plugin template you will see an example of an ever running thread. Yes, you can have something running non stop in the Event Server.
Yes, the sample is a good example of the admin part and I hope you can take this as good inspiration even if you do not need the client part.
On licensing the MIP SDK has three samples on using MIP licensing, you can use your own scheme or leave it out. MIP licensing is an offer to you if you want to sell licenses to your customers, there is no license cost for you or your customers to be paid to Milestone for a plugin.
