Setting Camera Roles
Please, is there a way to programmatically assign a specific Role to a Camera?
Many Thanks,
Frediano
Yes. There are some ways (I do not mention them all but the ones I guess are the most likely to be what you need.)..
Using the Configuration API strongly typed classes:
ChangeSecurityPermissions
ServerTask VideoOS.Platform.ConfigurationItems.Camera.ChangeSecurityPermissions(String userPath)
Edit permissions.
Parameters
userPath User path. User path format: /User[SID]. ‘SID’ can contain role ID.
Using Rest API:
Change storage for device ChangeSecurityPermissions
I also found this older topic that might be interesting.
Sorry Bo, but it is non clear for me.
2 Questions:
  • how to address specific camera to set permission
  • how to set specific Role and not User
Many Thanks,
Frediano
The specific Camera object is what you can get from the Configuration API VideoOS.Platform.ConfigurationItems;
Snippet of code showing two ways to get the Camera object for a specific camera:
using VideoOS.Platform.ConfigurationItems;
private Camera CameraPicker()
Item cam = new Item();
FQID cameraFQID = new FQID();
ItemPickerForm form = new ItemPickerForm();
form.KindFilter = Kind.Camera;
form.AutoAccept = true;
form.Init(Configuration.Instance.GetItems());
if (form.ShowDialog() == DialogResult.OK)
cameraFQID = form.SelectedItem.FQID;
return new Camera(cameraFQID);
else return null;
private Camera CameraFind()
ManagementServer mgt = new ManagementServer(EnvironmentManager.Instance.MasterSite.ServerId);
var cam = mgt.RecordingServerFolder.RecordingServers.FirstOrDefault().HardwareFolder.Hardwares.First(x => x.Name.Contains(“Test”)).CameraFolder.Cameras.FirstOrDefault(x => x.Name.Contains(“Test”));
return cam;
And a snippet of code how to read and change security permissions, note how it uses a role, not a user:
private void CameraPermission(Camera camera)
	var role = mgt.RoleFolder.Roles.First(x => x.Name.Equals("Operator"));
	ServerTask servertask = camera.ChangeSecurityPermissions(role.Path);
	if (servertask.ItemType == "InvokeInfo")
		ICollection<string> keys = servertask.GetPropertyKeys();
		foreach (var key in keys)
			string property = servertask.GetProperty(key);
			label1.Text += $"{key} {property}" + Environment.NewLine;
			if (key == "GENERIC_READ")
				string newProperty = (property == "False") ? "True" : "False";
				servertask.SetProperty(key, newProperty);
				label1.Text += $"Property change - {key} set to {newProperty}" + Environment.NewLine;
	servertask.ExecuteDefault();
The code is first draft, please use only for inspiration.
Many Thanks Bo, it works perfectly
Frediano
